kz1300 banner
Foggy tail/stop light lens
  • kza13
  • kza13's Avatar Topic Author
11 years 3 months ago
#6710
I have a couple of stop light lenses and after being in the aussie sun for a lot of years they got sort of dull and cloudy, thought i'd give that Meguiar's PlastX clear plastic cleaner and polish a go, seems to work well, just did a bit of a polish and they are clear and shiney, bit more elbow grease and they would be great, just thought i'd let you know, cheers Pete.
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
  • kza13
Re: Foggy tail/stop light lens
#6711
Hmmmmm ... might give it a go on the gauges Perspex cover, that's looking a bit dull also, damn theres a lot of plastic :)
  • Kawboy
  • Kawboy's Avatar
#6715
I like it !! Any chance Meguiar's put a UV protector in that product?
  • trikebldr
  • trikebldr's Avatar
#6725
Wonder how it might work on a windshield on a Voyager?
  • scotch
  • scotch's Avatar
11 years 3 months ago - 11 years 3 months ago
#6729
To keep my glider canopy free of scratches I use a 2 part "Mequiars" cleaner and polish. This may be a less aggressive product then KZA uses. The 2 bottle kit does a remarkable job but does take a lot of elbow when initially starting. I found that deep scratches must be carefully prepared with 1200 wet-n-dry before this product will give results. Once the item has been polished to a satisfactory finish the frequent routine cleaning will keep the plastic in a crystal like appearance. I found that a clean cotton dish-towell or a piece of felt worked well to apply and work the products. This left an almost "swirl" free finish which is the goal when you have to look through the canopy, facing the sun. Signal/tail-light lens would certainly be less critical. Well worth the effort.
Always High - Know Fear !
Last edit: 11 years 3 months ago by scotch.
  • kza13
#6739
Kawboy wrote: I like it !! Any chance Meguiar's put a UV protector in that product?
lets see how it goes in the aussie sun, i'll let you know in another 36 years :-)
Moderators: dcarver220b
Time to create page: 0.158 seconds
