1983 ZN1300 Street build.
- Nick89
- Junior Member
Re: 1983 ZN1300 Street build.
10 years 10 months agoPhil wrote: I don't see how fitting pod filters will hurt the fuel injected bikes, although the DFI system won't compensate for it. You can always fit an adjustable fuel pressure regulator to compensate anyway
I actually have an aftermarket adjustable fuel pressure regulator and fuel pump. So this is good news!
- Nick89
- Junior Member
Update.
Electrical all put together but I'm not getting any spark and no power to the fuel pump. Yay 32 year old wiring.
Now I got about 20 connections to test and this zn1300 harness has a ton of unused wiring now that all the extra bs is gone.
Anyone have a 1983-84 Kz1300 or Z1300 harness that had the DFI fuel injection?
- Nick89
- Junior Member
Systems removed:
Trip/fuel eco computer.
Compass computer.
Air ride pump and system.
Sound, Stereo system.
Accessory lights.
Did the trip/ fuel economy computer have anything to do with the ignition or fuel system? I didn't think it did.
Compass computer.
Accessory lights.
- aus_z1300
- Elite Member
An adjustable fuel reg might be an ok dodgy fix for a drag car or bike running full throttle for 10 seconds or so but don't think for a second it is going to sort out the fuel mixtures for you they will be all over the shop.
- Nick89
- Junior Member
10 years 9 months ago - 10 years 9 months ago
So far the stock wiring harness is trash. Most of it is dry rotted.
Looks like I'm going to have to wire up a complete custom harness. I can get a Mega squirt to replace the stock ECU, because I'm not even sure if it still works. Or I can get a set of carbs.
Carbs would be less wiring and trying to program the mega squirt.
But its very hard to find KZ1300 carbs.
I was thinking of using three GS500 carbs with custom brackets. Each cylinder is 216cc and the GS carbs are used for 243cc cylinders. It should work.
Last edit: 10 years 9 months ago by Nick89.
- Phil
10 years 9 months agoIt sorted mine, as verified by an exhaust gas analyser at the local bike dyno. The fuelling was pretty consistent across the boardaus_z1300 wrote: An adjustable fuel reg might be an ok dodgy fix for a drag car or bike running full throttle for 10 seconds or so but don't think for a second it is going to sort out the fuel mixtures for you they will be all over the shop.
The following user(s) said Thank You: Nick89
Moderators: dcarver220b
Time to create page: 0.175 seconds
