1986 ZG1300
- kwak1261
Re: 1986 ZG1300
10 years 4 months ago
it appears that i have an oil pipe running into the back of the camchain tensioner,
does this solve the problem of the tensioner letting the chain go slack ?
if not would it be a issue to replace it with an APE manual tensioner and just block of the oil pipe.
i could bore a hole through the new bolt and replace the oil pipe if needed.
any ideas..? Ian
any ideas..? Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
- kwak1261
Re: 1986 ZG1300
got the water pump and thermostat housings off, both a useless, the expanding bypass pipe has cracked both parts
attacked the swing arm to remove it from the frame.
i love what it says in the book to remove the pins. insert a 5 mm bolt in the center and pull. :woohoo: :woohoo: yeh right
the replacements will have an 8mm thread so that a slide hammer can be inserted.
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
- biltonjim
Re: 1986 ZG1300
A shame to see that this bike has suffered so much from neglect. But I'm sure you will make a gem out of it - and what a sense of achievement you will have!
I'm curious about that cam chain tensioner. I remember reading that the injec ted models had that oil feed to the tensioner, but what does it do?
- Phil
Re: 1986 ZG1300
I have an '84 ZG & mine doesn't have that oil pipe to the CCT. I seem to remember that the later fuel-injected bikes (Voyager included) had that system, where the CCT is tensioned according to oil pressure.
- kwak1261
Re: 1986 ZG1300
10 years 4 months agoPhil wrote: system, where the CCT is tensioned according to oil pressure.
wow thats a novel idea, ok as long as you have good oil pressure.
ill be swapping it for and older type with a back stop .
thanks Phil.
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
- rickster
- Junior Member
Re: 1986 ZG1300
Hey kwak hope the rebuild goes well you got any leads on the bits you need ????
Moderators: dcarver220b
Time to create page: 0.171 seconds
