Yellow Perils Up-date
- kwak1261
Re: Yellow Perils Up-date
9 years 10 months ago
Im not putting any pictures up from inside my shed, ill get a right roasting.
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
- Mark
- Elite Member
9 years 10 months ago - 9 years 10 months ago
Engine Painting progress, working around this now layering it on coat by coat using a heat gun as I go to help with the going of process using an Hammerite smooth straight from the can. Might keep the yellow water pipe on as a reminder.
Attachment not found
17 years a Z13 owner at present 3 x A1's and an A4
Last edit: 9 years 10 months ago by Mark.
- Tonto
Mark, that looks very nice indeed, has a factory / OEM finish to it !
Ive used PJ1 and Simoniz engine enamels on other project bikes: I never considered Hammerite as was not sure about heat resilience; but will defo be using it on my Z13 when I need a freshen up. Thanks for the tip.
Cheers Tim
Cheers Tim
The following user(s) said Thank You: Mark
- strate6
Simply the most impressive engine ever fitted in a motorcycle...........and you just made it the best looking too !
Great job that mate..........looks fanatastic.
I can assure you that paint will stay on the motor forever as long as you prepared the metal correctly before spraying, which it looks like you did.
Now its just getting it back in the frame without marking It !
Please show us the finished result.
Pete F
UK
Pete F
UK
- Ledkz1300
I wrapped my engine in an old blanket so I could get it in without bumping it around and scratching the finish. Once where it needed to be I cut the blanket away and there wasn't mark on the engine. Awkward but no marks.
- hillsy
Don't know if this is practical for the Z, but for all my previous 4 cyl bikes it was easiest to lay the motor on its side and lift the bare frame over it to bolt the engine back in. Not sure how much a 13 frame weighs.......but it's got to be less than the motor....haha....
Moderators: dcarver220b
Time to create page: 0.177 seconds
