kz1300 banner
new zealand rebuild
  • rob
  • rob's Avatar Topic Author
  • Senior Member
  • Senior Member
Re: New Zealand Re-build update
12 years 4 months ago
#1596
If anyone is interested. Yamaha xj 550 tailpiece and seat (80-82)with kawasaki tail light, I think z90 :P 00 or similar. Rear grab handles (easy for tying gear down) kz1000, look closely at photos. Paint job not done yet as I am too busy riding it. Ha Ha !!
  • BigSix
  • BigSix's Avatar
#1604
Bit short on the end, unusual to me, but has it's own look - well done.
regardZ
Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
  • tackelhappy
  • tackelhappy's Avatar
Re: new zealand rebuild
#1622
Just a question on the YSS shocks- Iv'e had the RG 362-360-TRCL for a number of years but have only just got the spring rate correct for my weight- which isn't much. I started out with the Black springs 46-20-30-220 , but they were way too hard.
What spring are you using Rob ?
I also using up front the YSS fork valve with Voyager 12 springs, taped out the schrader valve and used the thread with adjusting nut so as to add pre-load to the fork. Basically converts the fork to a more modern cartridge type- and therefore more adjustable.
OKANAGAN FALLS. BC ,Canada
  • rob
  • Senior Member
  • Senior Member
#1645
hi tackelhappy
I am only 74 kgs and have my springs set as the photo shows. This is a little bit hard for me but the difference in performance as regards to cornering is worth it. The springs I am using are 46-20X40X240. Hope this helps.
Moderators: dcarver220b
Time to create page: 0.209 seconds
