On the road again, yay.........short lived arrghhh
- RickG
Re: On the road again, yay.........short lived arrghhh
10 years 7 months ago
What a bummer but the positive side is that at least you didn't hit the starter button.
Z1300 A1 x 2
Z1300 A1 x 2
- kza13
10 years 7 months agoBoy will you be sorry you mentioned the solenoid valve, I was after one a while ago to complete my resto and asked if anyone had one, I was sorry I did, anyway the solenoid valve was not a good idea, so I was told, as it was believed that it would play up and shut off the fuel while you were riding and leave you stranded on the side of the road, so everyone took it off and threw it away. I had problems with a carb rebuild kit a while ago and did a post here showing the new clips for the needle valve were sometimes binding on the needle and holding them open, I had a flood of fuel one day and that was because I relied on the floats to work and didn't turn off the old petcock valve, a bad habit to get into, even though the sidecar holds my bike upright and I don't use the sidestand. I changed to the vacuum petcock and fixed the clips by using the old original Kawasaki ones and (touch wood) haven't had a problem since, well I lie, I did have a fuel filter that was too small for the required fuel flow, changed that to a bigger one and all is well with the world at present.Mark wrote: These bikes were initially fitted with a Fuel Solenoid shut Valve electronically Operated and bolted to the lower section of the air box, this provided a positive shut off when not running. For some reason people removed them am not sure why, I take the view that it is a good idea to re-fit. Somebody may say different and know the reason, I would be curious as to what this is.
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
The following user(s) said Thank You: Mark
- Kawboy
During your carb rebuild, did you change out the Orings between the needle seat and the carb body? I found that particular oring on my carbs had shrunk due to the ethanol in the fuel and it could lead to fuel passing around the needle seat and flooding the carb. Viton O-rings will handle the ethanol where as the nitrile O-rings which are supplied with most of the carb kits will not handle ethanol. KZQ added a reference in the FAQ section regarding the Viton O-rings.
- kza13
He's an aussie, we don't have the ethanol in our fuels unless you fill up with the E-10, just saying ... no offence meant
- RickG
10 years 7 months agokza13 wrote: He's an aussie, we don't have the ethanol in our fuels unless you fill up with the E-10, just saying ... no offence meant
Don't say it too loud Pete! The gubbermint mugs are probly lissnin in. :whistle:
Z1300 A1 x 2
Z1300 A1 x 2
- Torque59
- POTEST ALITER SUBVENIRI NON POTEST PRO CUBICUS
10 years 7 months ago - 10 years 7 months ago
Hello again, another quick update.
Have taken the cabs off and swapped over the needle valve retainers. What a difference between the two.
As Pete rightly pointed out I'm an Aussie so we don't have ethanol in our fuel and the o rings appear to be ok, however as I have them apart I'll change them out just in case. It's Sunday here so will have to wait until tomorrow to get them.
Next thing I did was drop the oil, again just in case. I am pleased I did, it was like a petrol bath in there. Took the oil filter out also. Will replace them tomorrow as well.
Hope this is not going to be a regular occurrence.
Still at a loss as to where all the fuel has come from. The fuel tap is in the correct position NOT on prime. When I took the fuel line off from the tank no fuel ran out from the tank as I would have expected if there was a fault with the tap. All the carbs still had fuel in.......got me buggered.
Oh I meant to mention in my first post that I had a strange water weep/leak.
It appeared to be coming from under the tappet cover at the front of the engine on the left hand side.
Had a good look in there and can't see where it could have been coming from. Can't see any trace where it has run down from somewhere else and there is nothing in the tappet cover area there to leak from. Strange, will investigate further when I have her running again.
Anyway will keep you posted as I try to sort this saga out.
Cheers for all your help / advice
Restored an 1976 Suzuki GT550B
Restored an 1982 Kawasaki Z1300 A4.
Also rides a 2014 Triumph Rocket Roadster, 2300cc of pure fun.
Last edit: 10 years 7 months ago by Torque59.
Moderators: scotch
Time to create page: 0.162 seconds
