kz1300 banner
Fuel flow slows when engine is warm
  • rdbhere2
  • rdbhere2's Avatar Topic Author
  • Elite Member
  • Elite Member
Re: Fuel flow slows when engine is warm
10 years 7 months ago
#9060
Clean
  • RickG
  • RickG's Avatar
#9061
Are you using a filter designed for a car i.e. the whitish opaque ones about 60mm long and 35 in dia. Don't ask how I know but I have a lot less hair nowdays. They will not flow enough fuel without the pressure of a pump.
Z1300 A1 x 2
  • rdbhere2
  • Elite Member
  • Elite Member
10 years 7 months ago - 10 years 7 months ago
#9062
I think it is but would that cause the petcock to restrict fuel flow when the bike warms up? Thanks
Last edit: 10 years 7 months ago by rdbhere2.
  • roadhazard
  • roadhazard's Avatar
  • Junior Member
  • Junior Member
#9063
I'm with RickG. I had the same problem using a car filter. It was bigger so i figured it's better. But it did not flow enough fuel to keep up. Had nothing to do with heat. Swapped it out with a bike filter and no more problems.
1980 Kz 1300 b2 touring
1980 kz 1300 A2
  • RickG
  • RickG's Avatar
#9065
It would not restrict the tap but it's still a good thing to get rid of. I had them on an R80GS/PD and one filter would not even keep one carb on one cylinder of a twin fed with fuel.
Z1300 A1 x 2
  • rdbhere2
  • Elite Member
  • Elite Member
#9067
Even when I disconnect the gas line at the top of the filter gas will not flow until the engine cools off.
Moderators: scotch
Time to create page: 0.165 seconds
