kz1300 banner
Carby troubles ?
  • toyinau2
  • toyinau2's Avatar Topic Author
  • Junior Member
  • Junior Member
Re: Carby troubles ?
12 years 2 months ago
#1818
Hi Pete
I did manage to get the pilot jets out with some effot and the cylinder that is not working was blocked completely at the time have replaced all jets and soaked and used air pressure through as many holes as i could but still no good . will try ultrsonic cleaning if no good will have to try another Carby . But not a lot of spares over here so would prob have to come from the States.
  • Toddh
  • Toddh's Avatar
#1824
Steve:
Like Pete recommends, sometimes your existing core set of carbs can be so problematic, it is just easier to find a new (Old) core set of carbs.
I went through three cleanings with carb kits, before I just called it quits and ordered what appeared to be a good used set online. Fortunately with a thorough cleaning and rebuild kits, this set has made the bike run the best it has in years.
Finding a good quality core set of carbs online can be dicey and is a hit or miss proposition. Whomever you buy them from, make sure they have a good return policy so if on initial inspection they don't look good, you are not out of your purchase price.
Regards.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • strate6
  • strate6's Avatar
  • On An Adventure Before Dementia ! !
#1825
Todd / Steve,
Just looking back on this post, Todd mentioned using White Vinegar as a possible cleaning agent.
I can second this as a very good method. My current 1300 had stood for quite sometime before I bought it & the inside of the tank was very rusty & needed de-rusting. I looked at many fancy tank cleaners (with their matching fancy price) but came across a bike forum on the web where someone had used White Vinegar to de-rust and old tank so I gave it a try.
After leaving the tank half full of the stuff & moving it around over a week or so I was absolutely gobsmacked how good a job it had done & made the inside of the tank beautiful silver fresh steel. I then coated it with Petseal Ultra & its all good & sealed now.
Todds post has made me think........if White Vinegar cleans steel so well, it must surely be just as good on alloy.
THE ONLY THING YOU NEED TO RESEARCH IS IF IT WILL EAT OR DISCOLOR THE ALLOY. ????
You could always test it with a small alloy part off old carbs first ?
If ok, then get your carb bodies in a bucket of the stuff for a week or so, changing position each day, and see how it copes.
I always find the natural remedies are best..........but hate the smell of vinegar !!!
Pete F
  • Toddh
  • Toddh's Avatar
#1830
While we are talking about rust removal, I recently ran across another method that seems to work. I have not used this product yet. As demonstrated on www.jaylenosgarage.com
Archoil produces their AR5100 that is supposed to do a good job on rust removal. It's a natural non toxic solution and it's is low cost. See Amazon link below. It can be re-used multiple times.
www.amazon.com/AR5100-16-Concentrate-16-...=8-2&keywords=aR5100
As with any tank project, it's all in the preparation and it is a must to methodically follow the directions.
I'm currently evaluating their friction modifiers and oil cleaner for crankcases. So far their fuel stabilizer seems to be working in my truck well enough to see if it works in the bikes.
The Youtube video below demonstrates the 5100's results.
Regards.
Todd.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
The following user(s) said Thank You: strate6
  • strate6
  • strate6's Avatar
#1835
Todd,
Very interesting, thanks for sharing.
Please let us know results on the bike.
Pete F
  • RickG
  • RickG's Avatar
#1842
Many of the older Mikunis are made of a zinc alloy and that and vinegar react very quickly so be cautious and try a small section on the outside of the body first.
Z1300 A1 x 2
Moderators: scotch
Time to create page: 0.160 seconds
