kz1300 banner
Spark plugs fouling
  • fabio
  • fabio's Avatar Topic Author
  • Junior Member
  • Junior Member
Re: Spark plugs fouling
5 years 9 months ago - 5 years 9 months ago
#27852
Hi.
The bike got 31000 miles.
The exhaust sistem is the original one.
For the air-injection ,i dont see any pipe or solenoid.
Last edit: 5 years 9 months ago by fabio.
  • strate6
  • strate6's Avatar
#27854
Air Injection ?????????????????
Thought it was a Carb Model ?
Pete F
UK
  • fabio
  • Junior Member
  • Junior Member
#27855
Sorry for misurandstanding:
it is a carb model,year 1980
  • scotch
  • scotch's Avatar
#27857
Thanks Fabio.
With the air induction system ("Clean Air System" - page 180) disabled the Enrichening system is redundent. Instead of removing 1 enrichening piston/diaphrgam; remove all three. A solid gasket will be required to seal the cover. Remove all 6 pilot (idle) jets and inspect with some magnification. If they appear tarnished.... coated with oxidisation, or look anything less then perfect - replace them. The need for these jets to be in new or as new condition can not be over emphasized!
See if this elliminates or improves your problems.
Always High - Know Fear !
Last edit: 5 years 9 months ago by scotch.
  • strate6
  • strate6's Avatar
#27865
Ahhhh......................
Air INDUCTION System..............................NOT Air INJECTION System.
Now it begins to make sense !
Pete F
UK
  • strate6
  • strate6's Avatar
#27866
scotch wrote: The bike got 31000 miles.
Thanks Fabio.
Scotch,
Please explain,
If removing the Air Induction System makes the Enriching System redundant, then why are the carbs on the EURO Model which is manufactured WITHOUT the Air Induction System still fitted from the factory with the 3 Pistons / Diaphrams ?
Pete F
UK
Moderators: scotch
Time to create page: 0.167 seconds
