Looking for the person that rebuilds/refurbishes KZ1300 carbs for around $650.00
- f_schenk
- New Member
3 years 8 months ago
- dcarver220b
Re: Looking for the person that rebuilds/refurbishes KZ1300 carbs for around $650.00
Here's the situ..
Called/Emailed Mike Nixon.. He's not doing kz1300 carbs anymore.
Recommended 'Wild George'.
www.wgcarbs.com/index.php
IIRC, $750 for the full monty.
Sent George money but not carbs yet...
As I'm working 72 per week graveyard now.
So not sure of quality, shipping, etc but thought I'd share the intel.
Hope it helps.
Hope it helps.
- dcarver220b
3 years 8 months ago - 3 years 8 months ago
WiredGeorge. Google it.
sorry, just off shift and I'm pooped.
George Lesho / Proprietor
Mico TX 210-413-1916 Mon-Fri 9-6 CST
Last edit: 3 years 8 months ago by dcarver220b.
- Kawboy
All you need to know to rebuild your own carbs cab be found in this step by step topic (tutorial)
1979 Carb rebuild Pt1
written by Scotch a few years ago. The only parts needed to do the rebuild is 3 o-rings preferably Viton to fit the float valve seats and 3 carb bowl gaskets or 1/16" gasket material and make your own. Attention to detail and follow the info and you'll be fine. Save the $650 and DIY.
The following user(s) said Thank You: f_schenk
- f_schenk
- New Member
Thanks,
In fact he's in the same state as I am
- f_schenk
- New Member
These carbs sat outside on the bike for ten years and throttle shaft frozen Did partially disassemble to soak got shafts loose but would feel more comfortable with a good disassembly and sonic cleaning.
Moderators: scotch
Time to create page: 0.167 seconds
