kz1300 banner
Knowing your Fuel -bowl levels
  • scotch
  • scotch's Avatar Topic Author
3 years 3 months ago - 3 years 3 months ago
#30979
I acquired a piece of 1/2" Lexan and wondered what I could use it for?
Always High - Know Fear !
Last edit: 3 years 3 months ago by scotch.
  • Kawboy
  • Kawboy's Avatar
Re: Knowing your Fuel -bowl levels
#30981
We're going to have to create a new model designation for that bike of yours. Shelby, Roush , ELR and now Scotch?
When can we expect the IPad diagnostics mod?
  • scotch
#30982
Q. - When can we expect the IPad diagnostics mod?
A.
Hold your horses Kawboy !  One hoof  at a time !
While doing a web-search for fasteners, I came a cross this:
A brass grease fitting with the same thread (M5X.5P) as the fuel bowl drain...
Drilled out the end and removed the check-ball and spring.
The rest is strait forward.
add an O-ring and......
  • Kawboy
  • Kawboy's Avatar
#30983
I do like the 90 deg elbow design . And a different way to milk a Kaw.
These are a #6-32 thread.
I did this mod a couple of years back
Last edit: 3 years 3 months ago by Kawboy.
  • scotch
#30984
I never did and still don't care for the '79 bowls. If you have experience with both styles you'll probably understand.  None-the-less.....  a bit of imagination, a few minutes at the bench and there's always  a (another) solution to a goal.
The idea behind the Clear Spacer is to eliminate the need for the level-tubes.
  • dcarver220b
  • dcarver220b's Avatar
#30987
scotch has some serious fab skills, just sayin'...
Moderators: scotch
Time to create page: 0.175 seconds
