DFI Fuel Injection and Fuel Pumps
- hoganter
- Senior Member
7 months 3 weeks ago
Hi MotoKa
I have been doing the same myself.
I put an adjustable pressure regulator and gauge in the line after the pump , so I could see what was going on.
I had replaced the original jec fuel pump with a walbro, however its too high capacity or volume for the new vacuum petcock or fuel valve, as it pumps 150 litres per hour.
I was getting bubbles in the return line.
So I moved the clear plastic filter to the pressure side of the pump and could still see bubbles.
Then I moved the fuel pickup to a jerry can and it was finally happy
Also check the return check valve as mine was blocked when I got it, and the tank was rusty.
I replaced the adjustable pressure gauge, because its bulky, with one very similar to the original from just commodores in australia.
A commodore is an aussie GM car . The VK model was built at the same time as the dfi and ran the 38 psi injectors. It also has the vacuum port that drops the pressure 2 psi when at idle. That's my understanding anyway but happy to be corrected.
My final issue ( hopefully after a year or more) is I don't want to be riding around nursing a jerry can.
Been looking hard for another pump that is a lot slower than the walbro.
I found a 50 lph bosch , but its an in tank version and I want an external.
Many pumps don't disclose what the volume is. Anyway I just bought an inline pump from china for a moto guzzi and try that.$80
I will rig up the old pump and just check what volume is does pump, and check the new one when I get it next week.
Have a fire extinguisher handy.
These bikes can also lose compression if they sit too long.
Good luck
Good luck
- KZQ
- Administrator
Re: Help with finding manuals
7 months 2 weeks ago - 7 months 2 weeks ago
Hello Hoganter,
Which Walbro pump were you replacing?
Bill
Bill
Last edit: 7 months 2 weeks ago by KZQ.
- kawaBCN
Re: DFI Fuel Injection and Fuel Pumps
7 months 2 weeks agoThis thread about fuel pumps may be helpful to you.Hi everyone,
I’m having trouble finding the service manual — I can’t see it on the homepage at all. Could someone please point me to the correct link? Ideally I’m after the DFI (EFI) supplement for the Z1300/ZN1300. I’m troubleshooting an issue and need to verify fuel rail pressures and related test procedures.
Many thanks!
DO I NEED A FUEL PUMP?
RUN LIKE THE WIND¡¡¡
The following user(s) said Thank You: KZQ, hoganter
- hoganter
- Senior Member
- KZQ
- Administrator
7 months 2 weeks agoHi Hoganter,Hi Bill
Its a Walbro 393
thanks
Why isn't the WalBro393 the right pump? The chart on their website seems to say that at 35 psi the 393 will flow 35 GPH.
Thanks
Bill/KZQ
- hoganter
- Senior Member
Hi Bill
I measured the walbro through a regulator which I think is 38 psi and got 4.8 litres in 2 minutes. 4.8 x 30 = 144 lph /3.78541 = 38.04 US gallons per hour
I measured the original Jec through the same regulator and achieved 2.6 litres in 2 minutes. 2.6 x 30 = 78 lph/ 3.78541 = 20.6 US gallons per hour.
So my original pump is about half the capacity of the walbro.
I am going to put the Jec back in because the new fuel petcock I bought is too restrictive for the faster walbro pump and I get bubbles in the fuel rail which causes it to run poorly.
Also the Jec looks like it has a check valve in it and I did not have one on the walbro ( not sure if it makes a difference)?
The original petcock may not have that issue but you need pliers to operate it, so I retired it.
The new one is vac operated but does have a prime setting. I was restricted for choice as I needed a 44mm to fit.
I have ordered a new moto guzzi pump but it has not arrived yet.
It should be all good
Cheers
Cheers
Last edit: 7 months 2 weeks ago by hoganter.
Moderators: scotch
Time to create page: 0.176 seconds
