VALVE CLEARANCE CHARTS
- biltonjim
- Torque59
Re: VALVE CLEARANCE CHARTS
10 years 10 months ago - 10 years 10 months ago
The rebuild is coming along well thanks biltonjim, I have just finished the head. Had to put a new set of exhaust valves and 3 exhaust guides in and 1 new inlet valve.
I set all the valve clearances on the bench so that is ready to go.
The barrels have been rebored and have fitted a new set of .05mm oversize pistons. I got them from MCG, very nice quality.
All that is left to do now is fit the barrels and head. I have been putting it off as I know what kind of a job this can be. If all goes well by the end of tomorrow they will be back on.Then just a matter of putting the head back on and all the associated bits and pieces.
I also took the time to go back through the carbs again as I felt that I still had a blockage somewhere.
As it turned out I did, I found that one of the idle circuits was partially blocked. Rechecked my float heights wet , all good.
There is now a definate light at the end of the tunnel, hopefully she will be back on the road within the next few weeks, fingers crossed.
Restored an 1976 Suzuki GT550B
Restored an 1982 Kawasaki Z1300 A4.
Also rides a 2014 Triumph Rocket Roadster, 2300cc of pure fun.
POTEST ALITER SUBVENIRI NON POTEST PRO CUBICUS
Last edit: 10 years 10 months ago by Torque59.
- Torque59
Hey Bill,
Those are the charts that I scanned and got my wife to shrink down to fit within an A4 page. I then got her to put in the 2 sets of circles to record the shim size in use and record the measured clearances for each valve, and the mileage. I like to have things written down in a simple format when I am doing these things, so just thought others might care to use it as well.
Cheers
T.J
Cheers
T.J
- Torque59
Will try again to upload the charts
- KZQ
- Administrator
Sorry TJ! I didn't understand that you had customized them for your use. I'll post them along side the manuals.
Bill
Bill
- Torque59
Hi Bill,
No worries, maybe the e-mail didn't send the entire page properly, just the chart and not the other modified stuff.
Anyway it's there now, all good.
Cheers T.J
Cheers T.J
Time to create page: 0.177 seconds
