kz1300 banner
Hand Grips
  • Mikez
  • Mikez's Avatar
  • Elite Member
  • Elite Member
Re: Hand Grips
12 years 3 months ago
#2122
kza13 wrote: Never had to worry about heated grips down in Australia, now if they made refrigerated ones I'd think about it :-)
Dang ... just checked, I'm out of grip glue, any other stuff we can use like contact glue ?
Might try something tacky but non-permanent. Like rubber cement or silicone?
  • Phil
  • Phil's Avatar
Re: Hand Grips
12 years 3 months ago - 12 years 3 months ago
#2128
I used to use the stuff sold as 'grip glue' & actually didn't find it very good. Someone recommended hairspray to me ...I was dubious, but trust me, it works! ;)
Spray copious amounts on the handlebar & on the inside of the grip, this acts as a lubricant to get the grip on, then as the hairspray evaporates it leaves behind a sort of lacquer which sticks the grip fast :) I used it to secure the Renthal grips on my 13 some years back & they won't budge :)
Last edit: 12 years 3 months ago by Phil.
The following user(s) said Thank You: kza13, zed_thirteen
  • kza13
  • kza13's Avatar Topic Author
Re: Hand Grips
#2147
Phil me mate, thanks, I had never heard about hair spray, great idea, i'll go get some and give it a go, that's what I love about swapping ideas, you learn something that you can tell others about, the major problem with my grips is that I steer a lot because of the sidecar, so I need something that will hold, thanks again, cheers Pete.
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
Last edit: 12 years 3 months ago by kza13.
  • Mikez
  • Mikez's Avatar
  • Elite Member
  • Elite Member
Re: Hand Grips
#2148
I've heard of using hairspray before but hadn't given it much thought till now. I'll have to try it myself lol!
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Hand Grips
#2151
Because I switch my bike between A2 and B2 from time to time I have to get the grips off so I can get the left hand switch gear off when I swap handlebars.
I've been trying to find some black CNC ally ones with rubber grip inserts that are the correct length but don't look like they belong on a hog. In other words not too custom. Most I've found are too short.
Anybody seen any?
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • kza13
Re: Hand Grips
#2152
Place here in OZ, seen these on the site, might be what your looking for ???
www.thirdgear.com.au/products/Black-Moto...lloy-Hand-Grips.html
P.S. got some "home brand" hair spray this morning, will try it out on new grips
