Electrical
Spark plugs.
- paulb
- Elite Member
Re: Spark plugs.
10 years 9 months ago
Hi
guys been trying BPR5ES plugs but still struggling with fouling of the plugs on initial starting and low speed, once the bike has started seems to be okay so I am thinking of trying the Iradium plugs , I saw mentioned earlier in the post eix8s can someone confirm
these are correct also any of the uk guys recommend a supplier
many thanks
Paulb
many thanks
Paulb
- McZed
- Elite Member
Re: Spark plugs.
I used BR8EIX iridium plugs in mine and it's running well. I bought them on e-bay. item No 151093036118
Z1300 UK
- paulb
- Elite Member
Re: Spark plugs.
Thanks for the reply, I will give them a try can I ask what you were using previously
thanks
Paul
thanks
Paul
- bassie20
- Senior Member
Re: Spark plugs.
paul, I have the same problem, let me know if the iridium plugs make a difference.
- McZed
- Elite Member
Re: Spark plugs.
10 years 9 months ago - 10 years 9 months ago
I was using the same plugs you are, had the same problems with them too. :dry:
Let us know how you get on the new plugs.
Z1300 UK
Last edit: 10 years 9 months ago by McZed.
- strate6
Re: Spark plugs.
10 years 8 months ago - 10 years 8 months ago
If your bike is fouling plugs when cold then its best to get that sorted before buying new plugs as you may well just foul them too.
Try screwing mixture screws in 1/4 to 1/2 turn and trying it.
Make sure 3 chokes are 100% closed when off.
Check float heights.
Try starting bike with NO choke or very little choke and warm up slowly...........you will be amazed how much good this will do for your bike as it lowers the amount of fuel into the cylinders which causes fouling.
Pete F
Pete F
Last edit: 10 years 8 months ago by strate6.
Moderators: scotch
Time to create page: 0.165 seconds
