- Thank you received: 3
Electrical
EUREKA MOMENT!!!!
- bobber-edd
10 years 5 months ago #10791
by bobber-edd
zed 13 1979 A1 model
EUREKA MOMENT!!!! was created by bobber-edd
AFTER a long time of wondering why the dam starter switch wont work ive fixed it.it was stripped right down and all the bits and those tiny springs and ball bearings and what an arse it was .Ive rewired the switch and it still didnt work aaaagggghhhhhhhhhhhhhh :evil: :evil: then the eureka moment :woohoo: :woohoo: i just looked at the laminated wiring diagram again and noticed :huh: the yellow wire with a red stripe from the starter solenoid actually goes to black wire with yellow stripe wtf well thats what thought ,and now it works perfectly
- aus_z1300
- Elite Member
- Thank you received: 21
10 years 5 months ago - 10 years 5 months ago #10792
by aus_z1300
Replied by aus_z1300 on topic EUREKA MOMENT!!!!
Japanese wiring can be a nightmare without following the diagrams. I once worked on a peewee 50 Wich you would assume the wiring would be very basic on . It had no harness and The stator and cdi wiring was colour coded and plugged into each other yet no spark.Turns out in the wiring diagram it changed colour once or twice and they swapped over and even had a diode in it for protection.
Last edit: 10 years 5 months ago by aus_z1300.
- bobber-edd
10 years 5 months ago #10793
by bobber-edd
Replied by bobber-edd on topic EUREKA MOMENT!!!!
yeah its not the only weird bit of wiring but at least its running now after 20 years happy days
- Kawboy
- Thank you received: 1198
10 years 5 months ago - 10 years 5 months ago #10795
by Kawboy
Replied by Kawboy on topic EUREKA MOMENT!!!!
Don't know how many times I've posted on this site, the best tool I ever made was to take the PDF page of the wiring diagram into my local printing shop and have them blow it up to fit an 11" x 17" page and then have it laminated. Then you can "see" everything and if you have to trace out wiring, you can mark up the drawing with a water soluble marker. After you finish "fixing " your problem, just wipe down the laminated drawing and hang it up in your shop. Makes for a great conversation piece and gives you an opportunity to brag about how you use this great tool to fix your ride. It's impressive even if it's only viewed by yourself. Hence the "Eureka Moment"
And Good job Bobber-edd for routing out your wiring issue. Electrical isn't a favorite topic for most people. But really it's just a road map with different signage.
Last edit: 10 years 5 months ago by Kawboy.
- stocktoy
- Thank you received: 90
10 years 5 months ago #10799
by stocktoy
Replied by stocktoy on topic EUREKA MOMENT!!!!
"Electrical isn't a favorite topic for most people. But really it's just a road map with different signage."
So true so true I never thought about the copier or enlarging (wasn't available to me at work) however on many an occasion I've just used a blank sheet of paper to make my own copy of a wiring section to help troubleshooting
- bobber-edd
10 years 5 months ago #10801
by bobber-edd
my wife recons its more like the london underground map lol,if I didn't have my laminated map from the internet supply shop I would of made my own like you said kawboy,Ive also just noticed that the yellow wire with the red stripe also goes to the cdi box and the yellow 3 wires to the coils
Moderators: scotch
Time to create page: 0.112 seconds
