kz1300 banner
Electrical
Fan switch rewiring.
  • strate6
  • strate6's Avatar
Re: Fan switch rewiring.
12 years 2 months ago
#2478
Standard 1300 fan switch cuts in between 95 & 105.
The temp rating is stamped on the switch itself.
Voyager cuts in a 85............much cooler, much better !!!!
Pete F
Uk
  • touringguy
  • touringguy's Avatar
  • Senior Member
  • Senior Member
#2734
My B2 touring model has a manual fan switch on the fairing. I haven't had the bike long enough to know if that's good or bad. The guy I bought it from said a previous owner thought the fan kicked in too late, so he wanted a manual switch to start cooling the engine earlier. I turned it on a couple time on warm days last fall, sitting at stop lights.
  • touringguy
  • Senior Member
  • Senior Member
#2735
My B2 touring model has a manual fan switch on the fairing. I haven't had the bike long enough to know if that's good or bad. The guy I bought it from said a previous owner thought the fan kicked in too late, so he wanted a manual switch to start cooling the engine earlier. I turned it on a couple times on warm days last fall, sitting at stop lights.
  • Toddh
  • Toddh's Avatar
12 years 2 months ago - 12 years 2 months ago
#2746
The fan switch can be a good idea depending where you ride. I know Missouri can get pretty warm.
As stated above, the KZ sender is supposed to kick in about 10deg later than the ZN (Voyager) sender.
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Last edit: 12 years 2 months ago by Toddh. Reason: spelling
  • strate6
  • strate6's Avatar
#2753
Todd,
Thats is my understanding & findings too.
The Fairing version bike kicked in earlier as it retains more hear around the motor due to the fairing & is carrying more weight.
In an ideal world you want a 1300 fan to kick in around 85 degs.
Pete F
  • kwak1261
  • kwak1261's Avatar
#2768
I have fitted a remote variable fan control with a capillary tube in the top hose,
i have left the stat out at the moment as i didnt want a conflict between stat opening temp and fan temp.
i might have to block the bypass tube until im happy with the running
Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Moderators: scotch
