kz1300 banner
Electrical
Dynatek DDK2-18C
  • f_schenk
  • f_schenk's Avatar Topic Author
  • New Member
  • New Member
Dynatek DDK2-18C
4 years 3 weeks ago
#30314
Anyone happen to have a Dynatek DDK2-18C Ignition Kit that's sitting on a shelf not being used? If so I am a buyer for it.
  • dcarver220b
  • dcarver220b's Avatar
Re: Dynatek DDK2-18C
4 years 2 weeks ago
#30324
Sorry, not me!
  • zed_thirteen
  • zed_thirteen's Avatar
4 years 2 weeks ago
#30328
I bought a faulty one of eBay hoping to fix the problem output but removing the resin pulled component from the board and made it useless.
I know Dyna have to protect their design but I bought my Dyna ignition to extend the life of my Z13 and Dyna quickly stopped producing it and removed support. If it goes wrong now it's just tough :-(
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • Kawboy
  • Kawboy's Avatar
4 years 2 weeks ago
#30330
Don't be throwing in the towel yet. I haven't seen a circuit board that couldn't be repaired. It's specialty work yes, but somebody should be able to help you out.
  • f_schenk
  • New Member
  • New Member
4 years 2 weeks ago
#30333
Any known systems that will fit / work?
  • zed_thirteen
4 years 2 weeks ago
#30335
I just can't find anything to shift the resin. I had been using a dremel to grind some away. You can see where two of the output transistors are lifted the resin pulled one of the resistors and some SMD capacitors..  There's a lot of green on the underside of the resin which could mostly be lacquer.
I need something that will dissolve the resin. Acetone isn't touching it
1980 CBX1000-A
1990 ZZ-R1100 C1
Moderators: scotch
Time to create page: 0.232 seconds
