Electrical
Wiring issue
- zed_thirteen
Re: Wiring issue
11 years 9 months ago - 11 years 9 months ago
glad you got it sorted.
On my bike there are a pair of black and white leads with bullet connectors under the tank near the front on the left hand side.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
Last edit: 11 years 9 months ago by zed_thirteen. Reason: change "started" to "sorted"
- Torque59
Re: Wiring issue
Thanks again. I will recheck and see what I can find.
Restored an 1976 Suzuki GT550B
Restored an 1982 Kawasaki Z1300 A4.
Also rides a 2014 Triumph Rocket Roadster, 2300cc of pure fun.
POTEST ALITER SUBVENIRI NON POTEST PRO CUBICUS
- kza13
Re: Wiring issue
I never found any wires to connect my clutch switch, not that I looked too hard, I just wanted the switch to fill the hole in the lever and to make the bike look original, will look closer next time I have the tank off, same as the oil level sensor, I have the sensor, motor has the later model sump, but no wire to plug it into, early model harness I guess, but I still have the wire going nowhere, cheers
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
- Torque59
Re: Wiring issue
:woohoo: Another mystery solved. Have been rechecking the connectors where I would have expected to see the two black/white wires for the clutch cut out to be.
Found that someone at some stage has cut them both off and spliced them together and bound them back into the main wiring loom with tape.
Obviously whoever had the bike previously didn't like having to pull the clutch lever in every time the bike was started.
Might leave it like yours Pete, have the switch in with wires leading to nowhere.
Not much left to do now.
Have to get an exhaust, rear shocks, caps and retainers for the coils, leads. Then it's all go.........hopefully
Moderators: scotch
