kz1300 banner
Electrical
Hazards only flash on one side
  • kennyb
  • kennyb's Avatar Topic Author
11 years 8 months ago - 11 years 8 months ago
#4712
My hazard lights were working fine until yesterday. I remounted my fairing and then did my ops check of the lights.Every thing works except the hazards. Only flashing on the left. I did some trouble shooting by swapping the flasher relay and also checking the connection. Have any of you run into this issue ?
Last edit: 11 years 8 months ago by kennyb.
  • stocktoy
  • stocktoy's Avatar
Re: Hazards only flash on one side
#4713
did you make sure the grd wire was put back on the turn signal mounting arm that might be the cause for the light to stop working?
The following user(s) said Thank You: kennyb
  • kennyb
#4714
Grid wire ? Not sure what you mean there. But the lights illuminate and signals work at least. Any one else care to chime in?
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
#4715
He's referring to the ground connection at each light.
So You're saying the bulbs illuminate but won't flash?
Bill
  • zed_thirteen
  • zed_thirteen's Avatar
#4716
looking at the hazard warning circuit on page 256 it looks like if one side is working then it must be the switch or the wiring from the switch to the side which isn't working.
It's unusual for the remaining side to flash on an old bi0metal can because they expect the load of all 4 bulbs.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • kennyb
#4722
The issue started when I re tie wrapped the wire bundle in the front as the factory did. Probably pinched a wire ? I'll look at it in the winter,But thank you all for your input ;)
Moderators: scotch
Time to create page: 0.173 seconds
