kz1300 banner
Cam Chain Idler Gear
  • Roadhazardguy
  • Roadhazardguy's Avatar
  • Senior Member
  • Senior Member
Re: Cam Chain Idler Gear
12 years 1 month ago
#3084
Ok cool, that's what I thought but I wasn't sure if the head would lift up high enough to clear the studs. Thanks
  • CR PURE-TON
  • CR PURE-TON's Avatar
  • New Member
  • New Member
11 years 10 months ago
#3991
I bought one, looks exactly the same than the original, same needle roller bearing, and the finishing standard very high.
I pay 99,95 $ (plus packing to spain), I will replace the nylon one next year (the installed one is still ok).
Do anyone already run the engine with Liska Racing unit on ?, if so any diferences during installation, noise....
Cheers
Carlos
  • kyscootertrash
  • kyscootertrash's Avatar Topic Author
  • Junior Member
  • Junior Member
#3998
Yes, I've installed one in my motor, and put about 10,000 miles on it so far. When first installed, you will hear some chain noise, which should quiet down in the first 50 miles or so. After that, you will hear a little bit of noise from the bearing in the center of the gear. I hope this helps.
The following user(s) said Thank You: CR PURE-TON
  • tackelhappy
  • tackelhappy's Avatar
#4000
And, yes mine is working. Especially useful if you actually ride the bike.
The factory option being a lot cheaper if the bike is used only once in a while
OKANAGAN FALLS. BC ,Canada
Moderators: scotch
Time to create page: 0.160 seconds
