kz1300 banner
Starter Clutch Query ???
  • Yaegunp
  • Yaegunp's Avatar
  • Elite Member
  • Elite Member
Re: Starter Clutch Query ???
10 years 6 months ago
#10137
KZQ wrote: Thanks Tim,
My starter clutch on the 1300 is failing differently that other Kawasaki starter clutches I have repaired, three so far. The starter will engage but if even one cylinder sputters the clutch looses it's hold and the starter just freewheels until it spins down, ending with a couple of noisy clacks. The only hope I have of getting the motor to start is a clean start right from the first revolution.
Bill
Bill, I believe I am having the same problem (in a fashion). I have just taken delivery of a new 'starter motor clutch repair kit' and was searching to see how to disassemble it all. Did you find what was causing the problem?
Paul
1983 Z1300 A5 plus Sidecar.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
10 years 6 months ago - 10 years 6 months ago
#10139
Bill
Paul
Yes Paul I did find the problem, although I'm not sure I understand all of it.
KZQ wrote: I've been an AmsOil user for more that 35 years and I've never had any problem until today.
I've had AmsOil in this bike for a decade with no problems. Just recently my starter clutch started slipping. Now, I've replaced starter clutches several times but the way this one was failing was new, at least to me. I'd pull in the clutch, hit the starter and the engine would turn over right up to the point that the first cylinder would pop at which point the starter would start slipping. At this point, all I can do is wait for it to spin down and come to a stop with several clanks. If the bike starts with the first pop, no problem but if it has to crank for any time it will likely slip on the first pop.
A mechanic friend of mine asked if I was using synthetic oil, said it was too slippery.
I just now changed the oil to Honda 10W40 Motorcycle oil, took it for a ride and the problem seems to have vanished. Could be that my starter clutch is just about to go and the slickness of the oil is right where it needs to be to show the problem.
I guess I'll stick with the dino oil, at least till I tear it down for some other reason to look at the rollers, springs and boss.
Bill
I still believe in synthetic oils and will continue to run it in my other bikes but here's one case where it seems to be too slick. In case you were wondering the other clutch works fine with no slippage.
Bill
Last edit: 10 years 6 months ago by KZQ.
The following user(s) said Thank You: Yaegunp
Moderators: scotch
Time to create page: 0.182 seconds
