Rattle when shifting into 2nd gear
- Ledkz1300
Re: Rattle when shifting into 2nd gear
9 years 9 months ago
Have you fiddled at all with your clutch adjustment? Sounds like its clutch related.
- RickG
I have been thinking it could be the clutch too. Have you checked to see if the plates have worn the basket, this can make the clutch bind a tad as you pull it in but if left for a bit (even just long enough to let the revs die back a bit) can cause the shifting to be a bit clunky.
Z1300 A1 x 2
Z1300 A1 x 2
- Tyler
- Elite Member
I agree its probably related to the clutch. I will start by checking the adjustment and see what happens. The clutch is one of the few things I did not take apart on this bike. I could see the friction plates were in good shape. I may have to have a look at it though.
1981 KZ1300
Moderators: scotch
Time to create page: 0.186 seconds
