kz1300 banner
New mechanical water seal leaking?
  • charlie9670
  • charlie9670's Avatar Topic Author
  • Elite Member
  • Elite Member
9 years 10 months ago - 9 years 10 months ago
#13733
Just fitted the new Kawasaki mechanical seal and put the rad on with water and it immediately poured out of the small drain hole which had previously been blocked. All looked ok to me when I put it together and I used white three bond liquid gasket on the mating surfaces. I took it apart and did it again..same result. I'm hoping there is a schoolboy error I've made (which I am prone to) but unsure what it could be. I'll walk away from it for the moment and get the coils and carbs back on. I hope as usual there will be suggestions to what is wrong or what I have done wrong, at least it all comes apart easily now!
:) Z13 UK
Last edit: 9 years 10 months ago by charlie9670.
  • Petez13
  • Petez13's Avatar
  • Premium Member
  • Premium Member
Re: New mechanical water seal leaking?
#13734
Did you remember to put a new o-ring on the impeller shaft?
  • charlie9670
  • Elite Member
  • Elite Member
#13735
No :whistle: ..will that let water straight through the middle and into the chamber with the drain hole, if so excellent, there's my schoolboy error..will look for an o ring..Thanks.
:) Z13 UK
  • charlie9670
  • Elite Member
  • Elite Member
#13736
:cheer: ..Brilliant, thanks Pete, all dry now, too easy to concentrate on the more expensive complicated bits and ovelook the cheap simple bits..easy for me anyway ;) ..the learning curve continues..upwards
:) Z13 UK
  • Petez13
  • Petez13's Avatar
  • Premium Member
  • Premium Member
#13737
Good I'm glad that sorted it, I've done the job twice and both times successful.
Not always the case with other things I've done on the engine.
Cheers Pete.
The following user(s) said Thank You: charlie9670
  • kwak1261
  • kwak1261's Avatar
#13740
its a good job you cleaned out that drain hole... :whistle: :whistle: :whistle:
well spotted Pete
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Last edit: 9 years 10 months ago by kwak1261.
Moderators: scotch
Time to create page: 0.169 seconds
