Time for a clutch?
- Lucien-Harpress
Re: Time for a clutch?
9 years 4 months ago
Nope, headers have to come off before the pan does. No easy way around it, unfortunately.
The following user(s) said Thank You: Ledkz1300
- Ledkz1300
Thanks Lucien. This is not going to be fun.
Any tips on how to go about it? Do I try to take it apart at the collector or do I remove the pipes from the head. It was a real bitch putting it all together. Took me weeks of fiddling to get rid of the leaks at the collector. Drive tap. Drive tap.
- Lucien-Harpress
9 years 4 months ago - 9 years 4 months ago
Hm.... If I remember how I did it, it may be worth dropping the whole thing. Start with getting the mufflers out of the way, then take the headers/collector off as a unit. You MAY be able to leave the mufflers in place and just take the headers/collectors off, but I don't know if you'll run into clearance issues. It may quickly become more trouble than it's worth.
As far as getting it back together, I always bolt everything up really loose so I know I can get everything started, then work from the headers, back- headers to block, collector mounts, muffler mounts. All the pinch clamps come last. Did you put in new muffler/collector gaskets when you assembled it last time?
Also, when you take the pan off, prepare for an absolute mess. It doesn't matter how well you drain the oil, a bunch will be left in the sump. Plan your pan removal location accordingly.
Last edit: 9 years 4 months ago by Lucien-Harpress.
- Ledkz1300
Well at least I only have one muffler. I have the DG 6-1. The collector starts just forward of the oil pan. I'm just not sure how to get the pipes out of the collector. They are rammed in pretty tight.
- Lucien-Harpress
Oooo. Can't help you too much, then. I'm still running a stock setup on mine.
- Ledkz1300
Moderators: scotch
Time to create page: 0.164 seconds
