pipe connectins kz1300a1
- Toddh
Re: pipe connectins kz1300a1
12 years 8 months ago
This system (First introduced in 1979) called the Clean Air System, on the MKII KZ1000 and the 1300. Thereafter on all models, and currently is on all Kawasaki Models and Engines in almost the same configuration, as introduced 35 years ago.
What I am saying goes counter to the above posts but here you go.
The system does work and robs almost no horsepower from the Engine. If left in place it requires little to no maintenance.
The largest headache with the system is access to the valve cover. But in the end is very easy to remove and reinstall.
The vacuum switch and reed valves can cause backfiring if they get dirty or malfunction. The factory shop manual provides very detailed diagrams, and gives a good description of how it works, and how to maintain it.
In short, it injects clean (filtered air from the air box) into the exhaust stream, at the base of the exhaust valve.
When I raced my KZ1000 in the 80's this was the first system to come off the bike. If they were daily drivers, I left the system in tact, so as to keep the engine burning as clean as possible.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- zoso
Thanks Bill - another job to keep me from getting bored during the winter.
Moderators: scotch
Time to create page: 0.176 seconds
