kz1300 banner
z-11cam chain tensioner
  • biltonjim
  • biltonjim's Avatar
Re: z-11cam chain tensioner
9 years 1 month ago
#16386
Yes, I agree with using the original tensioner, but with modification:
As Lare stated in his post here: www.kz1300.com/index.php/forum/engines/2234-cam-chain-tensioner
The following user(s) said Thank You: kiwirider
  • McZee
  • McZee's Avatar
  • Premium Member
  • Premium Member
9 years 1 month ago
#16387
I removed the manual cam chain tensioner because it was stiff to turn so I could never be sure the tension was set correctly. I re-fitted the original with the modification that I read about on this forum. The bolt stops the tensioner backing off if the non-return mechanism fails and the original spring keeps it at the correct tension.
Attachment not found
Moderators: scotch
Time to create page: 0.322 seconds
