kz1300 banner
z-11cam chain tensioner
  • jabee
  • jabee's Avatar Topic Author
  • New Member
  • New Member
8 years 8 months ago
#16352
Hi Guys I have just purchased a new z-11 tensioner from Z-power UK ,and on inspection find that there is a small rod included in the kit . Its about 4mm dia by 60 mm long. I thought it may be either to fit inside the spring to ,A -stop it collapsing sideways under comprression ,or B- to act as a stop in case of the rachet jumping and kicking back . Anyone know what its for ???
jabee
  • zoso
  • zoso's Avatar
  • Premium Member
  • Premium Member
Re: z-11cam chain tensioner
#16353
Hi
It goes inside inside the spring.
The following user(s) said Thank You: jabee
  • kza13
  • kza13's Avatar
8 years 8 months ago - 8 years 8 months ago
#16356
"A" for your answer, also it's recommended to trim the spring to not make it as strong for the 1300, pretty sure there is a thread here somewhere about how much to cut off, I think it was 10mm, but it's been a while since I did it so i'm not sure
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
Last edit: 8 years 8 months ago by kza13.
  • Phil
  • Phil's Avatar
  • 1984 ZG1300-A1 DFI
#16365
Yes it's 10mm
The following user(s) said Thank You: VieuxGrigou, jabee
  • Dion
  • Dion's Avatar
#16382
zzr100
Z1100
all the same tensioner?
whats the best to use
any one have best place /price to buy
thanks Dion
  • kiwirider
  • kiwirider's Avatar
#16383
Hi Dion zzr11/zx11 are the same i have read a lot on this forum about tensioners i have a new zzr11 tensioner which you can buy local and then cut 10mm of the spring .From what i have seen and read my option is to modify the original by drilling the end and putting a 6mm bolt and lock nut so you can tell when the cam chain tensioner shaft is getting to the end of its stroke and put a longer bolt and nut in where you lock the tensioner for assembly that turns it to a manual tensioner so it cant back out .
2018 Harley cvo ultra 1982 cbx1000 1980 gsx1100 2012 gtr1400 cx500 turbo 1977 suzuki gt750
Last edit: 8 years 8 months ago by kiwirider.
Moderators: scotch
Time to create page: 0.169 seconds
