Tach cable spewing oil
- Ledkz1300
Re: Tach cable spewing oil
8 years 9 months ago
Glad your repair worked. I ordered the replacement kit with seal and dropped it in. Worked like a charm
- Gavin
Great to see that you have sorted it, did you have any issues removing the tachometer drive from the cover? I ask because it is so close to the sides I am not sure if I have a socket thin walled enough
- Ledkz1300
I didn't have a socket with a thin enough wall. I used a pair of needle nose pliers... bad I know but I wasn't worried about chewing the old one up because I was replacing it anyways. It wasn't in super tight. I used the same pliers to get it as tight as I could and an open end wrench to carefully torque it tight. One tiny turn at a time. Didn't mark it up and it doesn't leak so I'm good.
Buy the right socket to make your life easier
Moderators: scotch
