Turning over engine by hand
- scotch
Re: Turning over engine by hand
8 years 7 months ago
Stan: There's a Pending Pat on your head if you do this !:whistle:
Always High - Know Fear !
- StanG
- Banned
- zed_thirteen
I wonder if there is a way to rotate the crank in a similar way through the casing above the starter gear? Would also mean that the engine could only be turned in the correct direction if at any point in the future some muppet decided to tinker.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- scotch
The "muppet" would be turning something on the starter-end forever with no results' because it's only centrifugal force that engages the starter-clutch mechanism.
- zed_thirteen
8 years 7 months agoscotch wrote: The "muppet" would be turning something on the starter-end forever with no results' because it's only centrifugal force that engages the starter-clutch mechanism.
I'll get my coat...
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- Phil
8 years 7 months agoDon't forget they didn't get "The Fast Show" in Americazed_thirteen wrote:scotch wrote: The "muppet" would be turning something on the starter-end forever with no results' because it's only centrifugal force that engages the starter-clutch mechanism.
I'll get my coat...
Moderators: scotch
Time to create page: 0.161 seconds
