kz1300 banner
Straight through exhausts
  • GP motorcycle customs
  • GP motorcycle customs's Avatar Topic Author
  • New Member
  • New Member
8 years 4 weeks ago
#19889
Hello
I would like to install a 6 into 2 straight through ( no baffles/mufflers ) exhaust system onto my z1300dfi, my question is what effect or damage may I cause too my engine or other components by doing this task ?
  • Phil
  • Phil's Avatar
Re: Straight through exhausts
8 years 4 weeks ago
#19903
Apart from being ear-splitting loud, it'll be OK.
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
8 years 4 weeks ago
#19911
I hate loud pipes, they freak me out make me cringe and can cause accident. Not good for any biker - which is riding every day and long trips. Personally, I am not a fan.
I have no idea how this would effect the KZ1300, as that would need to be academically researched. Based on other bikes, that would disturb the pressures in the engine resulting in actual power and responsiveness loss at certain rpm's. Would you feel it? Probably not. So, as Phil says, basically it's OK. But on the technical side, probably not good. Other engines need re-jetting. I will tell you - even displacing a vent hose on top of the carb on a Vmax to another place will badly affect the engine. The maker did lots of testing placing it right there for a reason, because of dynamics of air flow, temperatures etc. But would you feel any difference especially with loud pipes riding around town - my bet would be not.
  • New Member
  • New Member
8 years 4 weeks ago
#19913
Thank you and appreciate your replies and information for consideration.
Have a good weekend
  • Ledkz1300
  • Ledkz1300's Avatar
8 years 2 weeks ago
#20050
I have a DG 6-1 header. I've taken the baffle out for giggles. It gives a tiny bit of low end torque but works like utter crap at high RPM. Blows clouds of black smoke without the restriction of the baffle, which sucks too much fuel through making it run rich. It will also deafen you riding without earplugs. You would likely need to rejet if you plan to run open pipes.
  • rdbhere2
  • rdbhere2's Avatar
  • Elite Member
  • Elite Member
8 years 2 weeks ago
#20053
Moderators: scotch
Time to create page: 0.218 seconds
