kz1300 banner
Drive shaft boot clamps
  • Frank833
  • Frank833's Avatar Topic Author
  • Elite Member
  • Elite Member
7 years 7 months ago
#21822
The clamps on this basket case are rusted beyond use. Suggestions on where to find new ones? No need for authenticity. Nice new functional ones would be perfect.
These are about 105mm diameter and about 8mm wide. No idea what they even call these narrow band clamps.
  • stocktoy
  • stocktoy's Avatar
Re: Drive shaft boot clamps
#21827
Just a thought here, have you tried an auto parts store for CV joint, driveshaft or ATV shaft clamps of a similar dia. I also believe they make a tie strap style clamp in case you don't need to take the joint apart and only need to replace the clamp.
The following user(s) said Thank You: Frank833
  • Kawboy
  • Kawboy's Avatar
7 years 7 months ago - 7 years 7 months ago
#21832
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/kz1300/libraries/kunena/src/BBCode/KunenaBBCode.php on line 304. Please enable debug mode for more information.
  • scotch
  • scotch's Avatar
#21842
kawboy suggested: CV-Joint-Boot-Clips-Clamps-Stainless-Steel
Exactly what I was going to suggest. Used these to hold the collector-wrap and they're great !
Always High - Know Fear !
Last edit: 7 years 7 months ago by scotch.
  • Frank833
  • Elite Member
  • Elite Member
#21848
Perfect! Those had not dawned on me. I even have the “correct” crimpers for those clamps.
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
#21853
LOL Thank you Frank. I was thinking since I saw the post - how the hell do I tighten these? So.... there is a special tool for that. That means these clamps are a one time use?
Moderators: scotch
Time to create page: 0.201 seconds
