kz1300 banner
A5 with DFI head
  • Tad
  • Tad's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: A5 with DFI head
7 years 1 month ago - 7 years 1 month ago
#24048
yes that,s it stan. not sure if it was just a voyager head or all Fuel injection heads. I have proved the bike is a 1984 A5 for sure
frame is Kzt30A-016130
any idea if i can trace the same with the engine number. i can only find year and model info with frame info?
Tad
Last edit: 7 years 1 month ago by Tad.
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
#24056
Great, so it's confirmed what we figured out earlier. I am not sure about the engine. I think the numbers are different and you might not be able to see exactly what year - same crank case and other parts are interchangeable between models and years.
Last edit: 7 years 1 month ago by Kawboy.
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
7 years 1 month ago
#24057
One more. There should be a tag attached to the harness with a year on it as well.
  • Tad
  • Premium Member
  • Premium Member
7 years 1 month ago
#24078
cheers Stan
what i found out is---- the bike is a genuine 83 but registered in 84 A5 z1300. it has a ZG fuel injection head but still with carbs. the left handlebar switch gear is also ZG as it has a square plug for the clutch switch. not connected as lever housing is also incorrect.
all the rest is standard including exhausts.
thanks for all info o identification guys. will post a pic or 2 before i start working on her.
Tad
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
7 years 1 month ago
#24079
Always good to see the 'before' photos.
I am pretty sure you will see signs of work done after removing the cylinder head. You are going to do that, right? If all would be stock and look factory, it would mean your bike came with it like this - I've never heard of it from anyone so far. My bet would be on no possibility of that, and someone just switched the heads when doing the top end.
  • Tad
  • Premium Member
  • Premium Member
7 years 1 month ago
#24134
what i am doing is finding out what she is like before working to get her back on the road. ha only done 1000 miles in 10 years and i dont know the history.
starting is a little difficult as everyone else posts. it will start but cylinder 5 and 6 stay cold. reason is little or no fuel. my guess is its gummed up inside.
once runing for a while 5 and 6 cut in and it runs ok. check the bowl and fuel is now getting through.
took it out and it gets hot quite quickly. fan cuts in ok but still climbs into the red.
the water in the lower overflow tank by left foot is cold when engine is hot. not sure if there is an air leak or the pump is not turning?
all things to work on but nice to get anyone elses views.
once running its quite smooth so may not have to get the motor apart, so may not know about the head?
Tad
Moderators: scotch
Time to create page: 0.163 seconds
