Alternator rotor
- StanG
- Banned
Re: Alternator rotor
6 years 6 months ago
Glad to be of assistance. Indeed, one on the left looks shot. Looks like somebody tried to drill holes there? I seriously have no idea if the right one would work. My uneducated brain would doubt compatibility - just by the looks. Personally I'd question this and continue to seek a visually, at least, proper replacement.
If anyone else is reading, engine inner parts change color with usage. Darker orange like colors mean high mileage. The colors on the rotor I posted picture of is very pale, that's at 8000 miles. I think this is what a brand new rotor should look like. (when searching for parts from bullshitting sellers)
- ogri211
- Senior Member
The bike took a knock side on I think that whats damaged the magnets I will try it when I build the engine if it doesnt spark I will try the old one just to prove my wiring ,but I wont run the engine with the broken one, I have been looking for an A4-5 one for about 6 months I am sure one will appear eventually.
Z1300 A4,Z900 RS,Suzuki GT750A, Buell S1 Lightning, Royal Enfield Diesel. And Z900A4 on the rebuild.
- Kawboy
Orgi- Have a read of page 355 of the Main Manual. It's the supplement for the 1981 model and the page describes the double signal the IC Igniter requires, hence the 2 magnets. I doubt the 2 rotors as pictured are interchangeable unless possibly the IC Igniters are changed so that the rotors and igniters are matched.
- ogri211
- Senior Member
Im going to try it ,if it doesnt work I may grind a bit out the middle of the trigger, it is not magnetized, also it looks as if it may be soldered on so I may be able to remove it and solder on 2 small square, if I can do it without too much heat.
Moderators: scotch
Time to create page: 0.144 seconds
