kz1300 banner
Manual Timing Chain Adjuster Initial Cold Setting
  • scotch
  • scotch's Avatar
Re: Manual Timing Chain Adjuster Initial Cold Setting
6 years 1 month ago
#26558
I modified my stock tensioner with an internal nut, retained the internal original spring and locking collar. I rely on the spring to pre-load while giving the crank a bit of C.W. rotation. Then tighten the outside lock-nut. I do not "add" any tension. Still have 'teeth" on my nylon sprocket. 80,000+K
Always High - Know Fear !
The following user(s) said Thank You: rdurost
Moderators: scotch
Time to create page: 0.159 seconds
