Switzerland models power restriction
- Phil
Re: Switzerland models power restriction
5 years 11 months ago
On the subject of throttle action being limited I guess the way to check is to pop the airbox rubbers off the throttle bodies & see if the throttle butterflies open fully.
- norokstar
- New Member
Hi Phil,
Thanks for that- fair point I suppose. Something to look forward to when I come from sea!
All joking aside, it would nice if it is something as simple as that- if it is I'll let you (and everyone else) know- wont be for a while yet though, still six weeks at sea to go first!
Cheers,
Stuart
Cheers,
Stuart
The following user(s) said Thank You: Phil
- CraigH
- New Member
I am looking forward to your reply and what you find because I too bought a 87 DFi from Switzerland
- hoganter
- Senior Member
1 year 6 months ago
There are plates in the throttle body between the injectors and the intake, that look restrictive for the fuel. Part 13169-1744. I am missing one so trying to work out what their mission is before I put them back or or leave them out? They are a brass plate with two arms that slide into the injector aperture under the nozzle, blocking about 80% of the hole.
- dcarver220b
1 year 6 months ago
If it's blocking fuel flow..
I'd remove and see what happens!
..but you might want to install a kill switch tether so you don't whiskey throttle?
Just kidding.. but I'd remove them and see what happens..
- hoganter
- Senior Member
1 year 6 months ago
Thanks D
Yes am leaving them out. Got some feedback from a facebook z1300 group saying the same, but not a lot of information on them.
Moderators: scotch
Time to create page: 0.169 seconds
