kz1300 banner
Spacer behind starter clutch
  • toyinau2
  • toyinau2's Avatar Topic Author
  • Junior Member
  • Junior Member
12 years 7 months ago
#137
HELP can any one out there give me the de-mentions of the spacer that sits behind the starter clutch on the voyager type alternator system have just pulled it apart to repair the starter clutch to find some one has been here before and left the spacer out .
I will need to machine one up so if some one could give me the de-mentions Please.
  • Torque59
  • Torque59's Avatar
  • Premium Member
  • Premium Member
Re: Spacer behind starter clutch
#143
Hey,
I am not able to give you the dimensions you ask for but I have noticed on some of the OEM bike part sites, when you look up the exploded views ( find the part and number ) and check the part reference number out they sometimes give the dimensions, especially bearings and seals etc , so you might get it that way.
Hope this helps.
Cheers
Restored an 1976 Suzuki GT550B
Restored an 1982 Kawasaki Z1300 A4.
Also rides a 2014 Triumph Rocket Roadster, 2300cc of pure fun.
POTEST ALITER SUBVENIRI NON POTEST PRO CUBICUS
  • toyinau2
  • Junior Member
  • Junior Member
#147
Thank you Torque ill check it out .
Cheers steve
  • toyinau2
  • Junior Member
  • Junior Member
#148
Just a couple of Pictures of what happens when some dosent know what there doing .
A bogged up Job .
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
#155
Hey Steve,
Pics like that hurt!!!!
Fortunately the case seems useable. Not sure about where the missing shavings went. Hope you found them on the filter.
Good Luck.
Bill
  • toyinau2
  • Junior Member
  • Junior Member
#159
Yeh case is all good thank god just lapping the taper in a bit and she'll be going back together.
Bill do you like the coke can on the taper which spaced the roter out making the starter sproket just move where ever it wanted .I do hate people who dont know what there doing just imagine the rotor coming loose at say 6000 revs SCARY . it had just had an oil change but once its all bach together i'll warm her up and do oil and filter again (best time to do oil change is when it hot oil runs quicker bringing any rubbish with it .
Moderators: scotch
Time to create page: 0.171 seconds
