- Thank you received: 294
Rings finally settling in?
- dcarver220b
4 years 5 days ago #30384
by dcarver220b
Rings finally settling in? was created by dcarver220b
2022-06-04
Almost 180 miles on these plugs.
Regular gas this time, not Premium.Thought I'd take a look.
These are looking ALOT better. Perhaps the rings are finally settling in? Oil consumption is down, too.
Before, 1/2 to 3/4 of the window would 'show' after about 200 miles.
This time, it was down by about a tad.. maybe 3 to 4 mm's.
Plug 4 looks and 6 look a tad lean now?Will pull tank and look for boot leaks.
Whatcha all think? Too lean?
- Kawboy
- Thank you received: 1198
4 years 5 days ago #30385
by Kawboy
Replied by Kawboy on topic Rings finally settling in?
Agreed. For a carburetted engine, too lean. Especially 3,4 and 6 showing white ash on the ground electrode. If it was an EFI, it's manageable through programming to run that close to lean best mixture and not burn holes in the pistons. I'd work on getting closer to ash brown. Just a safer color to attain.
- dcarver220b
4 years 4 days ago #30386
by dcarver220b
Replied by dcarver220b on topic Rings finally settling in?
Well, no vacuum leaks. Sprayed suspension cleaner *highly* flammable the warning label states, all over intake boots and anywhere else I could get to. At least the carb bank is really clean.
ASSuming all mains, needles are identically set, why would only 2, maybe 3 be lean?
Any other things to check before pulling carbs for needle change?
Most of my riding is 20 to 80% throttle position. Very few 'fully on the main' runs... so I'm ASSuming raising the needle 1 notch on the hot holes?
- dcarver220b
4 years 1 day ago #30390
by dcarver220b
Well, humble pie time.
Used ColorTune, adjusted #4 for richer. Ok, let's put the plug back in.
Huh?
BP6ES? Shouldn't it be an '8'?
Why yes, it should. a 6 to ranges hotter than a 8.
So bought some 8's and will put them in, use color tune, adjust all 6 a teeny bit on the fat side and see what happens.
Huh?
- Kawboy
4 years 1 day ago #30391
by Kawboy
Huh ?? Looking at the Service Manual for the 79 KZ1300A1 BP6ES or BPR6ES.
- Phil
- Thank you received: 139
4 years 1 day ago #30393
by Phil
Replied by Phil on topic Rings finally settling in?
Seem to remember some NGK listings were incorrectly listed as "8" -it's too cold
Moderators: scotch
Time to create page: 0.158 seconds
