kz1300 banner
Rattle
  • PaulD
  • PaulD's Avatar Topic Author
  • Premium Member
  • Premium Member
Rattle
3 years 11 months ago
#30429
So the onward saga of the poorly Z13 continues
As if the carb problems ain’t enough to contend with (still playing up) I’ve now got a serious rattle from the bottom end? I’m hoping it’s the starter clutch come loose and is an easy fix but I’ve got a bad feeling about this. It started a while back but originally  I put it down to the cam chain with the carbs being out of balance. At first when I warmed  the motor up at low revs the noise went away after a few seconds but on my last test run after disappearing to start with it came back worse than ever while riding  and weirdly it got worse while hooning around left handers? Any ideas guys? this bike is really testing my patience
  • McZee
  • McZee's Avatar
  • Premium Member
  • Premium Member
Re: Rattle
#30435
Could be any number of things, does the rattle go away when you pull in the clutch? It could just be your clutch plates rattling.
The following user(s) said Thank You: PaulD
  • PaulD
  • Premium Member
  • Premium Member
Re: Rattle
#30436
Thanks for the reply but no it’s definitely not clutch related
  • Kawboy
  • Kawboy's Avatar
Re: Rattle
#30437
There have been a few reports of the starter clutch coming loose. StanG I believe showed the results of  his back 3 years ago? Try a search on the site. Best I can offer at this point. I'm  in a freakin hospital at the moment  working with a cell phone and no eyeglasses.
  • Kawboy
  • Kawboy's Avatar
Re: Rattle
#30438
Maybe this will help. Magneto puller  Don't  worry about the title. Read the link.
  • PaulD
  • Premium Member
  • Premium Member
Re: Rattle
#30439
 Thanks for that, fingers crossed that’s the problem. It definitely sounds like the noise is coming from that area of the motor. I’ll pull it apart and report back
Moderators: scotch
Time to create page: 0.175 seconds
