kz1300 banner
Possible cooling fan upgrade?
  • scotch
  • scotch's Avatar
Re: Possible cooling fan upgrade?
3 years 5 days ago
#31300
That's an intelligent choice for a fan blade alternative !  There's actually some serious engineering that goes into this type, including the OEM.
 Blade pitch, camber, chord, number of blades and in the case of the OEM, an interesting asymmetry of the blades relative to each other, which I suspect is to minimalize blade/air noise.
Always High - Know Fear !
  • Kawboy
  • Kawboy's Avatar
3 years 5 days ago - 3 years 5 days ago
#31301
Here's my tease for today-
If  had the time, Just for shits and giggles, I'd go with bladeless technology i.e. ala Dyson technology. Now THAT would be a head turner. Who's up to develop that??
Maybe I should just add it to the list??
LOL
an interesting read on  VTOL aircraft design using bladeless propulsion
Last edit: 3 years 5 days ago by Kawboy.
  • scotch
  • scotch's Avatar
3 years 5 days ago
#31302
great read on the aircraft !
As for a "Dyson" designed cooling system.  I'm sure Mr. D. could build something but it would cost $1000.00......Cdn !!!
  • dcarver220b
  • dcarver220b's Avatar Topic Author
3 years 4 days ago - 3 years 4 days ago
#31303
My kz is in perfect spot for a test fan upgrade. Headers off, new mechanical seal ready for re-install, headers ceramic coated.
New ignition coils and wires at the ready too.
Also complete WiredGeorge carb assembly ready too.
I'm thinking these changes might transform the old gurl.
I carb sync'd without doing all the prep work first..  of checking supporting sytems, thinking primarily (no pun intended) of the corroded spark plug terminals and broken coil casing.
We will soon see!
D
Last edit: 3 years 4 days ago by dcarver220b.
Moderators: scotch
Time to create page: 0.167 seconds
