Cylinder two not performing
- McBoney
Re: Cylinder two not performing
2 years 10 months ago
Just a thought,.... if the carb wasn't getting enough air or fuel, wouldn't that affect cylinder no 1 as well? I only had one cylinder not running.... which to me points to the spark.... and no 2 spark in particular, or the lead as if the coil was bad, it would affect another cylinder too.
Six-Pot-Cafe in the making...
- McBoney
right, ok, that makes sense re 'shorted' plug.
not sure if it was shorted, it looked OK and when taken out of the cylinder, it did spark.
I have no idea how that broke. I had some intermittent misfiring and when I took the leads off, the top of the plug in no2 came with it.
- McBoney
Ok, so I left the leads as they were and changed plugs 2 and 6 over after doing a compression test where all cylinders were 110-130 and took it for a short run... seemed OK, so not really sure what happened there.
I'll know more when I take out on a longer run, but with the lovely summer weather we have been having here in UK that may be a while...
Paul
Paul
Moderators: scotch
Time to create page: 0.158 seconds
