kz1300 banner
Hydraulic Clutch Slave
  • scotch
  • scotch's Avatar Topic Author
2 years 1 month ago
#32478
I did what some do when converting from cable to hydraulic.  I bought a used slave.
despite a new seal and some work involved in removing some bore scratches, it had an annoying, intermittent weep.
I Just replaced it with a new "Oberon".  I should have done this in the first place !
Always High - Know Fear !
  • Bucko
  • Bucko's Avatar
Re: Hydraulic Clutch Slave
2 years 1 month ago - 2 years 1 month ago
#32482
I can't remember .... somebody here tried using one of those hydraulic clutch cable end adaptors - was that you Scotch?
Last edit: 2 years 1 month ago by Bucko.
  • scotch
2 years 1 month ago
#32485
Not sure  what you mean by "clutch cable end adaptors ".
  • tackelhappy
  • tackelhappy's Avatar
2 years 1 month ago
#32488
Do you have any spares/ who made the mounting plate -I’m looking for two ?
OKANAGAN FALLS. BC ,Canada
  • scotch
2 years 1 month ago
#32489
I made my "plate" from 6mm aluminum.  No spares as I don't make them.
The following user(s) said Thank You: tackelhappy
  • Kawboy
  • Kawboy's Avatar
2 years 1 month ago
#32491
Pretty sure he's talking about one of these "alternative" clutch slave cylinders
The following user(s) said Thank You: Bucko
Moderators: scotch
Time to create page: 0.170 seconds
