kz1300 banner
Start up day
  • kennyb
  • kennyb's Avatar Topic Author
Re: Start up day
11 years 9 months ago - 11 years 9 months ago
#4363
I tossed the ballast resistor! I'm using a after market Dyna 2000 ignition system. The timing is good.The issue seems to be with the idle circuit. When I rolled the throttle and the main jets kick in it runs and sounds great especially with the DG pipe! When it is at idle it runs like sh$#! Back firing and popping etc. Too much fuel is going into the carbs it seems.The needles need to be adjusted it looks like?. The spark plug wires are also suspect as well. The oil leaks I will most likely just farm that job out to the local shop to replace the cylinder base gasket as well as the head gasket. But for now I'm just concerned about getting it running smooth.Just have to keep an eye on the oil level if you know what I mean :P
Last edit: 11 years 9 months ago by kennyb.
  • kza13
  • kza13's Avatar
Re: Start up day
#4364
Fuel level in the bowls ??, too high and it will make it run bad
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
The following user(s) said Thank You: kennyb
  • kennyb
Re: Start up day
#4365
That is true! I will add that to my bucket list of things to look at. I have the carbs off the bike and will check for sure.The needle on the carb where do you have yours set at? Again I am running a DG pipe and 105 main jets,thank you.
Moderators: scotch
Time to create page: 0.160 seconds
