kz1300 banner
Seat upholstery adhesive
  • StanG
  • StanG's Avatar Topic Author
  • Banned
  • Banned
7 years 7 months ago
#21843
I just went to Home Depot and the contact cement and glue section is a literally ZOO - all filled with gorillas!!! Gorilla glue that is, maybe 30 kinds of it. I have noooo clue what the heck they are, and description doesn't help - pretty much all say wood, leather, blah blah blah. I've read somewhere about 3M products as well, and others.
What glue or cement do you guys use? I changed the shape of the foam and will need to apply some adhesive to keep the top part of the aftermarket cover in place, and attach a bit of foam here and there.
Also - it would be great to strengthen the underside foam surface, as it became brittle in places. Seems spray would be best, but I don't want it to stay sticky!
Stan
  • stocktoy
  • stocktoy's Avatar
Re: Seat upholstery adhesive
#21845
Maybe you can try weather strip adhesive (yellow glue) very sticky and I don't think it desolves the foam.
  • Frank833
  • Frank833's Avatar
  • Elite Member
  • Elite Member
#21849
www.3m.com/3M/en_US/company-us/all-3m-pr...85+3292639006&rt=rud
Your local auto parts should be able to get a can for you if they don’t have it in the shelf.
  • StanG
  • Banned
  • Banned
#21852
That might be it Frank. Sounds strong and flexible. Thank you.
  • scotch
  • scotch's Avatar
#21854
Personally, I'd just buy any Aerosol "contact" adhesive. You don't need to soak the foam and cover-back. Typically an even spray coat on each piece is more then adequate.
Always High - Know Fear !
  • StanG
  • Banned
  • Banned
7 years 7 months ago - 7 years 7 months ago
#21856
I went to Can. Tire and Home Depot asking exactly for this - no luck, they know shit... Could you suggest a link?
Last edit: 7 years 7 months ago by StanG.
