kz1300 banner
If you make pieces and parts or provide services for Kawasaki Sixes you may post links here to your business or product catalog. If you're just into 1300's and have found a business that you like to deal with post it up here.
Aftermarket thermostats
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
Re: Aftermarket thermostats
6 years 11 months ago
#24500
Perhaps that's what it is - a stuck open thermostat that lets the coolant circulate all the time. I think you have no choice but to remove it anyway. It's possible something (like a piece of silicone) got stuck there and keeps it open. Cleaning it might solve the problem if you're lucky. It's a simple working gadget.
  • Phil
  • Phil's Avatar
#24517
I'd be dubious about it running cold Gavin, are you sure the temp. gauge is reading correctly? If the fan comes on at standstill then I think you can rule out running too cool. The DFIs seem to run rich in the UK, I checked everything (all checked out) & ended up putting a resistor in parallel with the air temp. sensor to offset it's reading. I get nice tan brown coloured sparkplugs now.
Time to create page: 0.158 seconds
