Best fork oil
- Artsagas
- Junior Member
Re: Best fork oil
12 years 5 months ago
Thanks a lot, Toddh, great piece of advice. While not ready to go into XXI century with my Rhino forks yet, :silly: I guess I'll stick to fork fluid and your recommended brands. I guess 10w is a good weight choice (?) and I'll double check all the other parts in there as well. I will keep you posted, guys! Best regards
Arturo
1982 Kawasaki Z1300
1982 Kawasaki Z1300
- zoso
Re: Best fork oil
I use 15w fork oil as I found the 10w stuff a bit thin. The front end was a bit spongy with 10w but not now. I used Putoline HPX15 Synthetic 15w.
- Toddh
Re: Best fork oil
12 years 5 months agoArtsagas wrote: Thanks a lot, Toddh, great piece of advice. While not ready to go into XXI century with my Rhino forks yet, :silly: I guess I'll stick to fork fluid and your recommended brands. I guess 10w is a good weight choice (?) and I'll double check all the other parts in there as well. I will keep you posted, guys! Best regards
Just reviewed the factory shop manual and it says 10wt to 20wt oil. I would second what Zoso says. 15wt would be a good start. The shear weight of the bike alone would require a heavier wt oil.
Just a suggestion.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- Artsagas
- Junior Member
Re: Best fork oil
Motul 15w has been chosen. I'll keep you updated. Thanks a bunch, guys!
Arturo
1982 Kawasaki Z1300
1982 Kawasaki Z1300
- Roadhazardguy
- Senior Member
Re: Best fork oil
Good info! If you're pulling yours apart you should do a how to if there isn't one already somewhere. It would be helpful for when I do mine.
Tony
Tony
- Artsagas
- Junior Member
Re: Best fork oil
12 years 4 months ago
Sorry, Roadhazardboy, job already done when you posted... By the way, 15w has been nice so far, a bit stiff but no problem for my 230 pounds. Put in 10 lbs of air pressure also. Great handling!
Arturo
1982 Kawasaki Z1300
1982 Kawasaki Z1300
Time to create page: 0.165 seconds
