Help: 90 degree Valve stem for rear wheel
- Bucko
8 years 3 weeks ago - 8 years 3 weeks ago
The valve stem in my rear wheel is a straight version and there's not enought room to get an air chuck on it to put air in the tire. I can get an adapter on there (maybe) for now, but for my next tire change I want to install a valve stem with a 90 degree bend. Does anyone happen to know the size (is it hole diameter?) that I need to spec for a replacement stem? (86 ZN1300).
Last edit: 8 years 3 weeks ago by Bucko.
- stocktoy
Re: Help: 90 degree Valve stem for rear wheel
8 years 2 weeks ago
not sure of the hole size however Goldwing's use a 90 degree stem
- Kawboy
8 years 2 weeks ago
I'm thinking the problem is the air chuck. Never had an issue with this one.
This one would be impossible unless you had a 90 degree valve.
- tackelhappy
8 years 2 weeks ago
Yep. I have the straight valve stem on my wheels , and that top photo of Kawboys post is the answer.
OKANAGAN FALLS. BC ,Canada
- scotch
8 years 2 weeks ago
YUP ! I have the same two air-chucks and it's the "shorty" only - that will work ! And now you won't have to re-balance the wheel !:silly:
Always High - Know Fear !
- Bucko
8 years 2 weeks ago
Yes, the one in the top photo would work; unfortunately, all my local air sources use the type in the lower photo.
Time to create page: 0.245 seconds
