kz1300 banner
rear master cylinder
  • paulb
  • paulb's Avatar Topic Author
  • Elite Member
  • Elite Member
7 years 9 months ago - 7 years 9 months ago
#21105
Hi
i dont suppose anyone has a rear master cylinder they want to sell. Mine is damaged beyond repair
many thanks
Paul
Last edit: 7 years 9 months ago by Kawboy.
  • Dion
  • Dion's Avatar
Re: rear master cylinder
#21107
Hi Paul
not sure what else could be damaged on the rear M/Cyllinder other than the bore
we stainless sleeve them here in NZ, im sure you could find some one over their who could do same/similar
then just put new cup set in.
if the threads for cap screws are gone , either tap ot and put Helicoils in or just tap over size and put bigger screw in
the glass site worst case scenario cant get one, tig it up or even use Devcon
the rubber would be similar size to front probably
failing all of that their is one off a GSX250 I THINK that with small work supposedly will fit
best of luck mate
Dion
  • paulb
  • Elite Member
  • Elite Member
#21108
Hi Dion
thanks for the reply, i destroyed the top of the master cylinder trying to get the screws out[so entirely my fault] and the metal around that area is so soft that it basically disintegrated making tapping out not viable but i will track one down
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
#21109
If you be patient with eBay you will find a good deal eventually. My rear master cylinder works well with the same old seals and after I manually 'honed' the bore with 1600 and 2000 grid. It's not perfect, but works. IN the meantime, I tracked another one on eBay. I am going to rebuild it and probably swap with the one I have. The whole assembly: rear brake caliper, line, the master cylinder bracket with the whole cylinder assembly complete, including a usable dust boot, cost me US$ 15 (fifteen). So, they are out there if you have time to wait for it. Lots of sells in the USA offer free shipping as well to a US address.
  • paulb
  • Elite Member
  • Elite Member
#21110
Thanks Stan
i am in the uk but have brought loads of stuff from the states because there seems to be more available[although not so much now] probably the kz1300 sold a lot more units in USA and Canada than uk
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
#21111
I think most were in the USA. The one which I have came from Washington. You are right - most available original parts are from the USA, but most after market parts are in Europe. Sometimes things are available in Canada, but much rarer. All the salvage places I visited here in my area don't even have one single KZ1300 part, and they said they never had one in at least a decade. A good thing for me is I live really close the border, and can use a mailing address service there for a USD 3.75 per package. It still makes is much cheaper.
