kz1300 banner
Can't lift to Center Stand anymore..
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Can't lift to Center Stand anymore..
5 years 1 week ago
#29288
yes - you should have regular tyre type valves in the top of the forks.
There are normally rubber caps over the top of the fork leg. These will pull off to reveal the valve. An A1 should have a valve in each fork and they need to be the same pressure (7.1 to 10 psi).
Later models only have a valve in the top of one of the fork legs and have a balance pipe that runs between the two fork legs under the top yoke
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
Time to create page: 0.154 seconds
