kz1300 banner
Fork Seal Replacement, (a mini how-to)
  • dcarver220b
  • dcarver220b's Avatar Topic Author
5 years 6 months ago - 5 years 6 months ago
#28369
Sorry for re-direct but pics don't easily transfer from my CandyButtAssociation website.
Last edit: 5 years 6 months ago by dcarver220b.
  • Kawboy
  • Kawboy's Avatar
Re: Fork Seal Replacement, (a mini how-to)
#28370
Just a thought Don.
if the dampening rod bolt doesn't tighten, won't the fork oil leak out past the bolt?
  • dcarver220b
#28383
Kawboy, It's very snug, just not fully tight. And I use these oil pan washers from BMW to be sure.
I need to read the manual to see if there's a tool to keep the inners from rotating when attempting to tighten the lower fork leg bolt.
Don
  • Kawboy
  • Kawboy's Avatar
#28388
FWIW Don, I've run into this before and found that if I used my 1/2" air impact and blipped the trigger it would spin the bolt fast enough to get the bolt to bite. Once it was nipped up, I get the torque wrench out and finish it off. You could probably achieve the same thing with an electric drill if you don't have an impact.
  • mizztheman
  • mizztheman's Avatar
  • Elite Member
  • Elite Member
#28391
This is a pretty common issue on forks of this type of construction. I had the same issue when I rebuilt the forks on my GT750. The solution was to use a 1/2” thick rod about 3’ long, I ground a 4 sided point on the end of the rod and I slid it down the fork stanchion to hold the inner tube in place when tightening the bolt. I had to do this when I rebuilt the forks on the Z1300.
You can use the existing copper sealing washers If you anneal them. Just heat them up to a dull red colour and then quench them in water. I always put a smear of 3 bond on the sealing washers.
Last edit: 5 years 6 months ago by mizztheman.
  • Bucko
  • Bucko's Avatar
#28392
Broom handle.
Time to create page: 0.171 seconds
